IGNIS ADL 334 – fill-in then drain water in cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum IGNIS ADL 334 – fill-in then drain water in cycle
  • #36714
    alzspb
    Hello 🙂
    I have dishwasher IGNIS ADL 334 with service sticker:
    8545 334 01010
    33 9620 003042
    Trouble is next:
    – after switch-on, machine start drain water with pump
    – next start fill-in with water
    – next AGAIN start pumping-out water
    ….e.t.c.
    I have no service manual and electric diagram of this machine.
    I`ll glad to see any help with files and advices.
    Greetings from Russia.
    With best wishes, Akesey.
    #252039
    Re: IGNIS ADL 334 – fill-in then drain water in cycle
    Hi Aleskey.
    You need to run the test programme to give you an indication of what is wrong. With the machine switched off, press and hold the “Start” and the “Eco/Bio 50c” button; then switch on. When the start LED starts to flash, let go of the buttons. The programme LEDs will light in different patterns to indicate a fault. Make a note of the lights by number, from the left to the right and let us know.
    alzspb
    This is sketch of control panel my machine:
    I have only one buttton and mode selector lever.
    #252041
    Right…… Not the same as the ADL334 over here then :rolls: . I will go and find someone who knows the answer!
    gegsy
    If you have a fault, the “Start” lamp will flash from 1 -9 flashes.
    To me that sounds like a clogged Water Indicator, found below the filters at the 3 o clock position.
    Its round with a mesh front. Try gently cleaning that with a toothbrush.
    alzspb
    Thank You to all 🙂 Problem is solved.
    Reason of malfunction was NON CORRECT setting-up of machine on the floor level. Dishwasher has a tilt about 4cm to down of left/door corner. In result, in time of working water throw the left green plastic tube flow to lower pallet. “Aquastop” was activated and machine stopped blinking with start light.
    After flushing lower pallet machine start cleanse salt-modul fill-in then drain water in cycle. After 10-30 min of this NORMAL washing was be contunued.
    After correcting level of machine all working FINE 🙂
    Thank you from Russia for help.
    PS: FC “ZENIT” – Champion! 🙂 FC from our city.
