I have started the programe for our dishwasher this morning and there is a constant beeping from the dishwasher. I have tried to reset the programe (water is still where the float/water indicator is and in the bottom where the filter is) to no avail. Any ideas please or if I can download a guide.
Thanks.
Hi Deltra,j ust noticed that you are from Workington, if I can not get the dishwasher sorted could you recommend someone to have a look as I am from Whitehaven.
Small world!!!
In the meantime, and if you are of a practical bent……
Bail out as much water as you can. Pull the plug. Remove the lower front cover plate. The drain pump is at the front and is a twist fit to remove. There may be a foreign object in there, or the pump my have failed. The impellor should resist and “ping” quite freely when turned manually; he coil should read somewhere around 200 ohms if metered.
