Re: Ignis ADL 347 integrated diswasher
Hiya,
It’s a Whirlpool machine and if you’re not getting any error codes it’s possible the module has failed. The module cannot check itself so doesn’t give an error code when it throws it’s hand in.
If you are getting a flashing start button you’ll find the fault codes are posted for Whirlpool dishwashers.
With washing up liquid having gone through I would have expected a flooded base. If it’s deep enough and shorting out the pump (only happens if it has an Askoll one, this has the power connections on the bottom, daft idea that) then you can get a dead machine with no error code.
There are 4 machines listed with this model number. You’ll need the 12NC number to get the correct module, if you need one.
Brian
