Ignis ADL 348
  • #74913
    gary996
    Have a problem on said dish washer. When switched on it starts up and every thing is fine, but it stops after a short while and just beeps continuously. When you open the door the rinse cycle light is on (even though I set the Hottest cycle).
    Another note. The RCD for my kitchen circuit had tripped out prior to this and we set the dishwasher start before we go to bed. I believe the dishwasher tripped the RCD out.
    Could it be the heating element?
    Many thanks Gary
    #393220
    gary996
    Re: Ignis ADL 348
    Have got the fault code if this helps F3
    #393221
    Specialist01269
    Re: Ignis ADL 348
    Hi: Going on your description of the fault & the error code then the problem is probably a faulty element. The only way to test properly is with a Megger.
    #393222
    gary996
    Re: Ignis ADL 348
    I have a Megger 1730 (electrician here)
    Hoe do you get access to the element?
    #393223
    Specialist01269
    Re: Ignis ADL 348
    Hi Garry: I believe on this 1 you get at the element by removing the back panel.
    #393224
    gary996
    Re: Ignis ADL 348
    Cheers mate. Will take a look a come back with what I find.
    Only downside is its intergrated so have to dismantle the kitchen
    #393225
    Specialist01269
    Re: Ignis ADL 348
    :eeek: Good luck mate, I’m not a great fan of Integrated appliances. Often takes twice as long to dismantle the units as it does to find the fault 👿
    #393226
    gary996
    Re: Ignis ADL 348
    Ok have stripped it all out.
    You have to lay it down and remove the bottom panel.
    Have put a continuity test on the element and don’t get a reading at all. A 500v insulation test across the element gives a reading of >999 and just to be sure putting 230v across the element I have no current reading on a clamp meter.
    I think this pretty much tells us the element is caput. Do you concur?
    #393227
    Specialist01269
    Re: Ignis ADL 348
    Hi Gary: Sorry for the delay in replying mate, yep I totally agree with you. No need to apply power to the element though your 1st 2 tests were spot on.
    Andy
    #393228
    gary996
    Re: Ignis ADL 348
    Have changed the element and all is working as it should be>
    #393229
    Specialist01269
    Re: Ignis ADL 348
    Hi Garry: Nice 1 mate & thanks for letting us know the outcome 😀
    Andy
