Re: IGNIS ADL347 8 FLASH ERROR
Have tried these both are ok
Water level control failure. Two possibilities.
1/ Easy one. Pull the filters and look into the sump, find the black grille at the 3 o’clock position. This is the water level indicator; it fills with fatty congealed deposits and can jam the mechanism. A vigorous attack of hot water and toothbrush may get it working again. It’s possible that the microswitch has failed. The unit is a twist fit from underneath if you need to remove it. Power off, first.
2/ More complex. The flow meter in the fill matrix under the left hand side panel is not signalling. The usual problem is the connector to the little pcb. Removing it and cleaning the contacts, as well as giving the connector a good pinch will often get things going again.
Hope this helps
Thanks again
