ignis ADL347 854534715410 Fills then empties
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ignis ADL347 854534715410 Fills then empties
  • #40266
    alro
    Hi gents
    Need help have an adl347 fills then empties no motor action error fault is 1&2 flashing flow meter faulty spins ok checked connectors & cables to pcb ok tested water indi in base of sump plus connection all ok pcb looks fine .Customer used dishwasher went away for 2 weeks this fault happened on 1st use of return any ideas suspect lower pcb
    cheers alro
    #265366
    Re: ignis ADL347 854534715410 Fills then empties
    1+2 flashing is not a fault code…… The pattern of the flashing start led is a code – ie, 1-2-3-4-pause, repeat.
    Has the base gort water in it ?,Common problem that the hose perishe’s and then leaks.The appliance will the operate the anti flood and pump out.
    Bryan
    #265368
    alro
    CHRIS & BRYAN
    thanks for reply flashing 1&2 is the code for flow switch fault as per sios disc f5 no pause bryan the base looks as thou its came out of a show room new no leaks, have taken side chamber off and flow switch spins ok seems to be like new does any body how to test the switch. WI switch makes 1to3 empty then with water in 1to2
    cheers alro
