Ignis ADL347 Dishwasher 11 flashes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Ignis ADL347 Dishwasher 11 flashes
  • #27110
    Simon46
    Got this one 854534715820 with OWI fault. Diaphraghm ok and microswitch changes state ok. Fills and fills then 11 flashes. What is the part number for module? Or is there another fault that can cause this?
    Regards
    Simon
    #212649
    robwash
    Re: Ignis ADL347 Dishwasher 11 flashes
    F11 is the WI membrane switch. forget the module. even if yiu think the membrane switch is ok …it isn’t. part no.481227128407
    #212650
    Simon46
    I have checked the switch changing state as it fills(physically and electrically both in and out of the dishwasher). expected that it was that but no.I have not had one like this before.
    Regards
    Simon
    #212651
    robwash
    hi. even if you have checked the switch it has to be changed. i’ve had this fault many times and it is this. not a control board. i know this is hard to understand but its true. cheers rob
    #212652
    Simon46
    Rob will change and see.
    Regards
    S.
    #212653
    Simon46
    Been back to this one.Does askoll wash pump read 32 ohms? seems that base was flooded wash pump connector burnt/shorted and has killed module(no rcd in house). What is the partnumber of the module for this?
    Regards
    Simon
    #212654
    goosegreen
    Simon, Have seen this before but managed to re solder the wire from the blown motor connector back on to the PCB. Good option as the boards are not cheap.
    Goose
    #212655
    Simon46
    Ta Goose but module will still not cut off on fill.
    S.
    #212656
    goosegreen
    Just remembered the one I repaired the module on did exactly the same. Found that the small connection to the water sensor on the left hand side needed drying and tightening a bit. All in all a pig of a job but as I had already fitted a motor I was not going to give up.
    Goose
    #212657
    Simon46
    To put this one to bed replaced module. Cuts off on fill ok. Tracks blown on WI and SPM. Was unsure of damage to components on PCB so decided to replace. Started up ok cut off on fill wash pump energized ok.
    All except a drip from the moulded rubber hose (intake side)on the giant askoll onto pump connector.:evil: .
    Caught out.
    S.
    #212658
    Hadn’t read this then?
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159
    Simon46
    Have replaced a few for no circ just could not test with faulty module. Leak on intake is a new one on me. Cust agreed to new pump at trade price 🙂 so at least i can salvage job.
    Thanks anyway Chris
    S.
