Circ motor shown on Connect for this is 5045174652872 @ £130 but via Currys partmaster (er Connect) which shows a different motor 5045175678956 @ £51 on Connect. The only difference ‘seems’ to be a gauze around the impellor shaft is that correct or are they not compatible?
The other thing is that the machine goes into circulate for around 2 minutes with only a faint hum from the motor then aborts, drains and beeps 4 times. Not had no circ registering a fault code before but there’s a first time for everything.
if this is the motor with the integral heater in the impellor housing then it will be the more expensive one. godknows why they fit these after the history of failure with the first askoll pumps.
Went back today (after getting two smashed ones from Conn) with the cheaper one as it was worth a punt. Difference…..the base bracket is at around 30 degrees to centre. Swap the bracket (rubber studs) fitted in no time and a free set of thin hose clips with it too 😉
Need another of these pumps. No stock anywhere and Connect have given the cheaper one a £27 price rise 👿 . Looking round there is nothing available quickly and at the standard retail of around £228 😯 who the bl***y hell would want one after only 14 months of working for just a couple.
