Ignis ADL349 Error 5
Viewing 1 post (of 1 total)
  • #59923
    kuango
    I believe error code 5 to be blocked rotor.
    Does this refer to the sprayarms being blocked or the actual wash motor blocked.
    The appliance will do all it should until it gets to the wash cycle.
    After Start.
    Drain Pump on.
    Solenoid opens. Water fills and stops then one more slug of water.
    Then nothing.
    If I leave it long enough the drain pump comes on then I get the error beep with 5 flashes.
    NTC – 60kohms
    Heater – 30 ohms
    Don’t know if this is relevant but no signal from the PCB for the heater coil at time of wash cycle.
    Any help appreciated.
    regards Tony
