ignis ADL934/1SWH 854593415750
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ignis ADL934/1SWH 854593415750
  • #73965
    alro
    Hi gents
    dishwasher select quick wash programme fills wash starts dispensor door opens coil clicking continuosly heater relay on bottom board clicking motor seems to be not washing like it was then start noen flades off and on,On more then off suspect bottom control board ?? do these machines have a test prog as the pcb is a bit expensive if wrong and its the top selector pcb also expensive or am i on the wrong track
    on visit it was flashing 8 times then pause?? reset to find the above problem cheers alro
    #389453
    Re: ignis ADL934/1SWH 854593415750
    sound like a board power supply problem
    see
    trade-technical/simple-pcb-repair-tips-t51155.html
    see if your board uses a capacitor for a power supply and if so change it
    alro
    DAVE
    can not see any damage on lower board have 240v going in will caps be out of shape and is the top board just a selector pcb cheers alan
    #389455
    cap will be where power comes into board
    if they have used one its a large grey or blue block with a value of 1uf to 2uf
    there will no visible signs of failure
    if your board uses a switch mode power supply like on hotpoint wma range there will be a small transformer and therefore not as easily repaired
    if you want to post a picture i wil look at it for you
    alro
    thanks Dave found the grey block 1.5uf change see what happens
    cheers alan
