ignis ADL934S 854593415750 3 FLASHES ERROR
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ignis ADL934S 854593415750 3 FLASHES ERROR
  • #89836
    alro
    Hi gents select programme (1 quickwash) machine fill dispensor opens heater come on heats water then you get a flikering on start neon then goes off but machine carries on neon comes back on flikers leave machine to run a few minutes heating up stops and flashes 3 times or fault 3 is this heater or heater relay fault code thro all whirlpool range or somthing else as some it works ok cheers alro
    #442709
    Grendal
    Re: ignis ADL934S 854593415750 3 FLASHES ERROR
    F03 is a heater fault ….but check the wiring loom as its a very common fault
    #442710
    alro
    grenal, pulled and check wiring at base of door area on bend no cracks or broken wire cheers alro
