Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Ignis AFE275 wont freeze – HELP PLEASE
- This topic has 9 replies, 4 voices, and was last updated 20 years, 9 months ago by
admin.
June 21, 2005 at 7:32 pm #10280
KeymasterHi,
We have an integrated Ignis freezer – model AFE275, about a week ago the freezer temperature started to rise inside (freezer is usually set to level 3 of 4 and has been fine for ages). Despite turning the freezer to the maximum level, slowly but surely the food began to defrost.
Anyway, the food had to be chucked away.
I took the opportunity unplug and to defrost the unit and clean it out hoping that when I turned it back on that it would be OK.
That was 2 days ago and the unit although cold inside it isnt actually freezing.
I do NOT believe that this was caused by ice build up (it seemed to be at the usual level) neither was the door left open at any point or the freezer too empty or too full.
The motor seems to kick in and out but it doesnt stay on for any long period of time.
A friend started to mention thermostats and thermsters… but I dont know anything about this kind of thing !!
PLEASE HELP !!!
Many thanks for any advice you can give
Many Thanks
LeeJune 21, 2005 at 9:13 pm #139324litlor
ParticipantRe: Ignis AFE275 wont freeze – HELP PLEASE
Sorry last message did not work lets try again
How long does the compressor run? Is it just a few seconds if so sounds like Relay or run windings faulty or if running constantly system blocked or gas leak probably a job for the profresnals not DIY im afraidJune 22, 2005 at 11:42 am #139325admin
KeymasterRe: Ignis AFE275 wont freeze – HELP PLEASE
… it runs (or at least it makes the noise) for 10+ minutes…. the freezer elements are freezing a little bit but a glass of water that I pu inside still hasn;t frozen after a few days.
June 22, 2005 at 12:53 pm #139326litlor
Sounds like compressor or system work to be done try Repairs@ for a local engineer
August 16, 2005 at 6:50 pm #139327admin
Actually you may be able to help me. I have the integrated larder fridge arl100. I for the life of me cannot find the serial number, which I need to report a fault. The horrible people at the manufacture’s customer care departnent hung up on me as they would not understand that there is not a number on the inside compartment of my fridge. There is not ione on the guarantee. Please can someone look on their ignis fridge (the model quoted) an help urgently? 🙄
You can reply to njfalkous@gmail.com
August 16, 2005 at 6:58 pm #139328litlor
ARL100 is the model number what is the problem??
August 16, 2005 at 7:03 pm #139329admin
Sorry I mean I need the serial number. The door started to jom (not as in the music sort) and when we opened it to investigate a washer/screw fell out of a white plastic insert attaching it to the freezer. As it is attached to a woden facade (it is an integrated fridge freezer) it keeps on coming away from the woodedn bit. Therefore we have to only open it slightly or else it will fall off. It is def a prob with fridge, not the way it has been placed on wooden facade. Can you help? The serial number begins with a 85 and I think has 9 munbers on it.
August 18, 2005 at 1:20 pm #139330ali-p
Hi – reply to Lee
sounds like a gas fault, but may be worth checking the fan at the bottom
Unplug first
Then check plug is out
Remove wooden plinth (if present) and remove 2 screws from flat plastic plinth on appliance – the fan is on the left (you cant miss it). Check it is free of fluff and turns freely!
If the fan cannot remove the heat from the condenser – thats the big black grid on the back of a freestanding feezer, it wont cool!
August 18, 2005 at 7:24 pm #139331litlor
I would imagine that Lee has had his appliance repaired or replaced now as it was posted on the 22 June
August 18, 2005 at 7:29 pm #139332Penguin45
Now, now – the info will be of use to future reader 🙂
