ignis akl 424
  • #13108
    this built in cooker doesn’t seem to work properly. The lower heating element doesn’t seem to switch on and the upper one comes on for a short while then switches off. Is this a fauty thermostat?
    The grill function is ok so I guess the uppr element is ok
    Any ideas what might cause the fault and how could it be reparired. Also might it cost more to repair than replace?
    #153204
    Dave_Conway
    Re: ignis akl 424
    Can you check that model number please, it doesn’t exist 🙂
    But, i think it’s just the base element has failed, the thermostat probe would normally be fairly near the upper element, hence the early shut off.
    #153205
    Re: ignis akl 424
    Sorry the model number is akl 404 not 424
    do you know how I get at the old one to replace it? Do I need to remove the oven from the housing or is it accessible from inside the oven?
    #153206
    Dave_Conway
    Re: ignis akl 424
    The oven has to come out of the housing to access, please remember to power off beforehand :zap:
    If the element proves to be the problem, it’s part number 481925928847 at £35.84 inc VAT and carriage which we can obtain for you, an email to spares@ukwhitegoods.co.uk 🙂
