IGNIS D/W
  • #21472
    Model is apparantly an ADL347, old dear has just rung me saying that she has a white piece that has fallen off inside.
    She says its made in Germany, are there any parts available for these?
    AMS
    Re: IGNIS D/W
    It’s a Whirlpool Jim, so parts should be readilly available from the usual sources. There are several variants of the ADL347 so service no essential.
    johnmac11
    Re: IGNIS D/W
    some of the ADL347 variants have a rubber bung in the top of the dishwasher. These are known to rot and fall inside causing water to go over the tank and on to the wash pump causing an earth leak.
    John
    #191003
    gegsy
    Re: IGNIS D/W
    johnmac11 wrote:some of the ADL347 variants have a rubber bung in the top of the dishwasher. These are know to rot and fall inside causing water to go over the tank and on to the wash pump causing an earth leak.
    If required Jim its 481246278998 – £5.19 list
    Re: IGNIS D/W
    Thanks guys, sounds worth popping round to have a butchers.
    Re: IGNIS D/W
    Just been to have a look at this. I have in my hand what appears to be the remnants of a seal, white, crumbly rubber, approx 2 inches in diameter, it looks as though something should be fitted inside this, there is a large hole in the roof of the inner cabinet, offset to the right of centre.
    There is also a much smaller bung of the same material, situated dead centre of the roof. That is also breaking up.
    Service No: is 096932. Data 096922 ( I think ) i was using a mirror to see it. 🙂
    It looks like I need the small central bung and whatever fits in the larger hole in the roof as well.
    Re: IGNIS D/W
    Anybody know the part number of the small central bung.?
    I have had a look at the picture on MP of the part number gegsy has given, that looks like the large bung, don’t know where the centre of it has gone, all I have is a white crumbly ring, and I don’t want any salacious comments about that if you don’t mind. 😆
    gegsy
    Re: IGNIS D/W
    Hi Jim
    That bung is one unit. The centre has just disintegrated. Remove left over bung and new one can be fitted from inside of cavity 😀
    Re: IGNIS D/W
    Greg, there are two bungs in the roof of this machine, one a large two inch diameter one, offset to the right and a small 10p sized one that is dead centre of the roof. That one is still in place but is also breaking down. I wanted to replace both to save another visit in the near future.
    gegsy
    Re: IGNIS D/W
    Hi Jim
    The small top bung is 481246278996 £3.10.This blanks off where the uplift pipe is secured on the new dishwashers.
    Regards
    Re: IGNIS D/W
    Cheers Greg, poxy quality rubber don’t you think. Reminds me of the second incarnation of Hotpoint dishwasher over 30 years ago, after the dreadful small Italian job that cost less than its own circulation pump. GEC bought a French company called Lincoln, possibly from Thompson and introduced a model of their dishwasher as a Hotpoint. It was built like a tank, ultra reliable in every way save for the fact that all the plastic fittings, filters, plugs etc used to melt like chocolate in a heatwave. Then came the Bosch produced 840/50/60/70 and all was well with the world. 8) 😀
