Ignis oven door seals
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Ignis oven door seals
  • #43288
    wilroda
    We have an Ignis AKL 335/01 fitted double oven/grill which was in the house when we moved in a few months ago.
    I am wondering if one of the oven door seals is missing – the bottom one on the main oven. There are holes there to possibly fit one but having looked on the net for replacement seals I see that most are three sided.
    which would stack up with the three that are there at present. I have noticed that the oven tends to ” drip” steam etc onto the grill/oven below, which makes me wonder if there should be a fourth.
    Can anyone tell me if there should be a fourth seal please!
    Thank you
    #276744
    Re: Ignis oven door seals
    Both door seals are three-sided.
    wilroda
    So….. if there are only three seals – should the oven drip steam etc?
    or is this normal..
    #276746
    Interesting point…….
    There is a marked temperature differential between the inner and outer glasses of the door, so I suppose there must be condensation forming as a result. A three sided seal being open at the bottom is presumably acting as an air intake for cool air (the oven has a hot air vent at the rear) to circulate, a proportion of the hot air venting at the rear.
    wilroda
    Thanks very much for that.
    So i guess i cant blame the oven for my bad cooking then!!……….lol
