Hello, I own an Ignis Electric Oven, model number AKL/404/AV/01 8541 404 15040.
Basically my oven door was fully open, I managed to trip over it and land on it, which resulted in it refusing to stay shut and it was clearly bent back further than it should. After taking the entire door off and inspecting it, the actual hinges appear to have torn through the inner door/plate metal (the hinges have basically gone the opposite way they should do, although they appear to actually be okay). I’ve taken the inner covering off and that problem seems to be localised to just the metal inner door/plate, but i’m unsure of the spring hinges or wether they are damaged too. I guess I should replace both the inner door AND hinges? If i do, i’ll be praying it actually closes and stays closed, otherwise there could be worse damage inside the actual oven. This is all rather baffling to me so any help or suggestions would be greatly appreciated. Thankyou in advance
Re: Ignis Oven Inner Door, metal torn?! AKL/404/AV/01
Hi Benjamin,
Can you give us the 12NC number off the rating plate so we’re sure it’s the right parts?
Expect to be shocked by the prices, it’s Whirlpool.
The big worry in all honesty, i stat the actual cabinet is damaged in any way where the hinges go in because, if that’s the case, the door will never seal properly again and it’s a new oven only as an option.
