Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › IGNIS washer suddenly doesn’t work… as silent as the grave
- This topic has 6 replies, 2 voices, and was last updated 11 years ago by
axxo1.
March 27, 2015 at 1:19 pm #84529
axxo1
ParticipantHello and thanks in advance to anyone that will help.
I have an IGNIS washer that suddenly doesn’t work anymore.
I select a program, push ON but nothing happens, washer doesn’t lock the door nor start…
I can’t find the model number
http://i.imgur.com/f3ZBLYr.jpg
http://i.imgur.com/P9YUA1s.jpg
http://i.imgur.com/LqbDpxY.jpg
http://i.imgur.com/YvFtjUB.jpgI checked
1) socket with a lamp, working
2) different programs, nothing worksIt was working perfectly before, no prior warning.
I don’t know if it is related but…
Recently I plugged a lamp that had a faulty cable that caused the house “main switch for plugs” (I don’t know the technical name) to go off.
However all other appliances are working fine.
As far as I know that switch works like a fuse…March 27, 2015 at 4:51 pm #425921Martin
ParticipantRe: IGNIS washer suddenly doesn’t work… as silent as the g
It’s a very tired looking AWP011/1. Judging by its state it could be anything TBH. Door lock problems? Main On/off switch? Circuit board?
March 27, 2015 at 6:23 pm #425922axxo1
Thanks Martin.
Reading around seems first thing to check in such cases is the door lock as you said.
The door makes the usual “SNAP” sound and is firmly closed.
Still, washer won’t lock it.Anything I can check with a multimeter?
March 27, 2015 at 8:42 pm #425923Martin
Power unplugged first then you can check the on/off push button switch for starters. How much electrical knowledge do you have?
March 30, 2015 at 7:28 am #425924axxo1
I have used a multimeter before… that’s all!
March 30, 2015 at 12:53 pm #425925axxo1
I am about to buy a new washer. Can you recommend any good brand? And what to avoid…
March 30, 2015 at 2:00 pm #425926Martin
Bosch still hold out as the best but mid range, not the cheap end.
