ignition fault
  • #77009
    tonyb87
    Hello
    I have a range cooker Diplomat gg 1000dl.The ignition works to light the four burners and oven on the right-hand side of the range, but not the left hand side. (on the left are four burners,a grill and another oven. Is this expensive to repair. Thanks for any replies to this problem.
    #400398
    Andy jones
    Re: ignition fault
    Probably only the spark generator. Shouldn’t be too costly but you will need a gas safety engineer to fit it
    #400399
    tonyb87
    Re: ignition fault
    Thanks for reply Andy,would a gas engineer be able to quote me a job done price if i mention your suggestion.
    #400400
    Seamy
    Re: ignition fault
    They should be, but they may need to confirm that this is the actual fault first. You can ask them, say what you think & the advice you’ve gotten, see what they say.
