ignition unit connections
  • #85616
    Tom
    I am Gas Safe Registered.
    Hoping some one can help.
    Need info on the wiring at the spark ignition unit on an electrolux EKG5546 gas cooker.
    😕 There are a lot of wires going to this unit!
    This is also where the mains input connects to this cooker.
    Needed to confirm the connections are correct.
    Any help much appreciated.
    tom
    #429068
    Re: ignition unit connections
    I can only find one basic diagram for that model (you didn’t provide the full PNc number ) but check this one out…..it’s a bit faint, but then E/lux aren’t exactly a guiding light anyway…..
    #429069
    Tom
    Martin, many thanks for your post.
    When printed it shows up not too bad.
    I’ll send on the product number later in case it is of relevance.
    I’me probably hoping for too much detail regarding the ignition unit connections i.e. coloured wires & ht lead — physical positions .
    I dont want to strip it to pieces to trace the wires, if I can help it.
    Everything is working as it should but am suspicious that wires were got at beforehand.
    tom
