ikea 401.451.57 blowing thermal limiter
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ikea 401.451.57 blowing thermal limiter
  • #91911
    char14lew
    service number: 857913915502.
    The customer complained this whirlpool appliance making a humming noise on the fan setting. I’ve had it apart and on test and it hasn’t made the noise.
    It then blew the thermal limiter, which I replaced because I thought it could have been that making the noise. It was fine on test but when she went to use the oven after it was dead again.
    I’ve been through all elements and fans and bulb,nothing is short or leaking voltage.
    any suggestions please?
    cheers Darrell
    #449680
    Re: ikea 401.451.57 blowing thermal limiter
    I am assuming the cooling fan runs ok and runs on after its turned off
    have you check stat temp as it may be high
    how do the wires and connections to the stat look? bad connection can cause extra heat and blow stats
    char14lew
    The cooling fan is only running on conventional oven setting.
