IKEA dishwasher Skinande 911536114 21552 ODD error
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries IKEA dishwasher Skinande 911536114 21552 ODD error
  • #95686
    asp11
    This seems to be an intermittant fault…. On 30mins setting it will work fine upto 13mins approx then stop and flash – cx not sure what sequence
    I did a function test alright on 30mins but after that time…. it went on and on heating more, washing more and stayed on 1min for ages
    I restarted it on rinses, it worked for 5mins then stopped and bleeped….. in the display was ( , 10 ) and the bottom of 3 lights flashing (cont) next to a rectangle icon with a circle in the middle??
    cx said if its off for a few days it will works again for a few washes then fail — any ideas??
    #461070
    difficult to know here
    there is an i10 error which is water fill error on static fill
    some of this range is listed as needing a pressure sw mod
    you show pnc as 911536114 but the is 2 more digits as there is a 00 01 02 03 04 and 05 versions
    asp11
    Thats the pnc in full, so normally that means it is a 00
    Do you know anymore about the pressure switch mod. ?
    #461072
    they added a pressure chamber inside the sump because early ones blocked up
    let me have an email will send some reading over
    asp11
    sorted
