IKEA DWF 415 S 8 flashes
Home Forums Public Support Forums Help And Support Dishwasher Help Forum IKEA DWF 415 S 8 flashes
  • #39670
    spesh
    Hi, My IKEA DWF 415 S has stopped working
    it gives me 8 flashes before going off
    I know someone out there knows what this means…
    Please help
    lots of other info on the side of the door
    typ:NGPM
    BOARD SERVICE 468591
    DATA:468581
    SER: 33 0245 012375
    #263158
    Re: IKEA DWF 415 S 8 flashes
    Water level control failure. Two possibilities.
    1/ Easy one. Pull the filters and look into the sump, find the black grille at the 3 o’clock position. This is the water level indicator; it fills with fatty congealed deposits and can jam the mechanism. A vigorous attack of hot water and toothbrush may get it working again. It’s possible that the microswitch has failed. The unit is a twist fit from underneath if you need to remove it. Power off, first.
    2/ More complex. The flow meter in the fill matrix under the left hand side panel is not signalling. The usual problem is the connector to the little pcb. Removing it and cleaning the contacts, as well as giving the connector a good pinch will often get things going again.
    Water indicator, if needed, is HERE.
    Fill matrix, if needed, is HERE.
    Stay safe, power off for anything other than observation.
    spesh
    thanks a lot for your reply – gave the bottom sections of the dishwasher a good clean, got rid of all the remnants of food etc and hey presto it started working again. The missus is off my back and the kitchen is shipshape yet again – thanks again!
    #263160
    Tell “THE BOSS” that rinsing the heavy deposits off the crockery prior to washing is essential – it’s a dishwasher, not a waste disposal unit……. 😀 If you feel lucky, of course.
