Ikea DWHb10 flow meter?
  • #60329
    Johnnyboy
    Hi folks this one starts drianing as usual then will fill and empty at the sasme time , it will then after 10-15 seconds bleep and flash fault 06 , if you choose another prog it will do the same except flash 7 times, Which fault do you think i should believe. ( it wont go into test mode)
    Cheers Johnnyboy
    #341814
    Re: Ikea DWHb10 flow meter?
    Don’t know offhand what 6 is but 7 is reed switch (search here if not familiar) and is very common, assuming it’s Whirlpool clone.
    Mike.
    #341815
    rolf
    Yes I have had reed switch fault show both 6 and 7 on whirlpools.
    Not cheap though you have to buy complete tank but sounds like your best bet .
    #341816
    Johnnyboy
    I take it that is the blue component on the water fill tank?
    #341817
    Yes. Just gently pull out the little pcb, buy a reed switch and solder it in. RS or radionics.ie part no. 2293692. Check orientation of old one before desoldering :wink:.
    Mike.
