Hi All,
Found the power was off in the fridge, light out and control panel off. Mains supply is good.
Upon powering on again at the socket, there are some relay clicks halfway up the left side of the unit. 3 short clicks, then 5 slower clicks then silence. The control panel does not respond and tried leaving the power off for a few minutes before trying again.
This integrated fridge freezer is 8-9 years old and has been running fine right up to when it was found dead. I’m suspecting something like a dried out cap in the control board PSU, a dry joint or a corroded connector. The fans and compressor have been running fine with no problems up to now.
Any ideas what to try next?
Thanks in advance
Dom
