Ikea Gorlig Oven (not heating) – grill & fan works
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Ikea Gorlig Oven (not heating) – grill & fan works
  • #99061
    Gokhk
    Hi all
    I have a ikea oven that seems to work fine on grill mode but not on oven modes , fan comes on but no heat.
    Assuming bottom element has gone but dont know which part number i need.
    Attached is an image of serial number https://ibb.co/q767hm1
    could someone give me compatible whirlpool or ikea part numbers please or a link to buy
    thanks again for your help
    #474887
    In that oven, I think the 12NC is 857912415500 from that image, there’s only the upper and lower elements in it that are as follows, cheapest options:
    https://shop.ukwhitegoods.co.uk/wp14107-compatible-grill-heating-element
    https://shop.ukwhitegoods.co.uk/ele9697-compatible-lower-oven-heating-element
    Gokhk
    Perfect
    I ordered the bottom one
    My worry is upper element doesn’t work on anything other than grill so could that also be faulty ?
    I’ll test continuity but hoping bottom one does the trick.
    anything else I should test or watch out for ?
    thanks again
    #474889
    Thanks and the outer of the upper element should be on when in use for the oven so I’d check that.
    Gokhk
    I see
    I’ll test again but if not could it be the thermostat or would the grill working rule that out ?
    when this issue started the red light wouldn’t come on but after 1-2 days it does so I’m wondering whether there’s a thermal cut out or something ?
    #474891
    The inner element on the grill would still work.
    A cutout etc is possible but not likely with the grill working.
    Thermostat, possible yes.
    But on those ovens the lower element does seem to go for some reason.
    Gokhk
    Perfect fingers crossed it resolves the issue
    thanks kwatt much appreciated
    #474893
    No problem.
