This dishwasher is dead. 240 volts to the main PCB. I’m not sure if the problem is the User Interface Board 140000453146 or the Main PCB 973911539179029.
The customer reported the panel lights were all flashing, she switched it off by the on/off button. Now it wont switch on.
Anyone have any ideas?
Check for voltage going to the display then check to make sure all wires are connected correctly and check to make sure you don’t have a broken wire. It could be both boards need to be replaced. Good luck
