Hi. Looking for a replacement for an IKEA oven model OVM610/S. (857922115001).
Width is 595mm but the height is 565mm. If anyone knows of something similar it would help. Cheers
The only reduced height single ovens out there are the compact appliances which stand at 455 mm tall. There is nothing else even on the Ikea site.
So the only way I can see it is you could remove a drawer, drop down the existing oven shelf to accommodate a standard 60cm tall oven. A fillet would need to be added under the oven shelf though. A fiddly job indeed but it’s the only solution I can come up with without spending lots of money.
