Ikea rengora 911 535 057
  • #92676
    ray.t
    Got this one that doesn’t heat. Checked heater and it is ok. The machine will run a full cycle without showing any error codes but just no heat. The machine is under 5 years old so should be covered by Ikea but the owner doesn’t have the paper work for it.
    I can see a temp sensor listed on connect so was going to try that first but just wondered if I should be looking at anything else first.
    Cheers,
    Ray
    #451862
    Re: Ikea rengora 911 535 057
    It’s a Zanussi with a badge stuck on it, so heater relay on pcb is always a good bet.
    P45.
    #451863
    bazza500
    Check the insulation of the heater. If it’s low it won’t heat but gives no error codes.
