Ikea Renlig DW60 (911 539 050) not heating
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Ikea Renlig DW60 (911 539 050) not heating
  • #98615
    davepi18
    The dishwasher has stopped heating. The program runs to the end, but it’s cold and nothing washes properly. The pump is running.
    I suspect the heating element, but I can’t determine if this model has a separate thermostat, and I can’t find a service manual or wiring diagram for it.
    If I need a new heating element, it seems spare parts are available, but it’s not clear to me how to replace it as it’s buried right at the back of the machine.
    So, is it likely that a new element is required?
    How can I check the existing element?
    If I need to replace it, how do I get to it?
    How can I get hold of a service manual?
    Any advice gratefully received!!
    #473055
    element should be this one
    https://shop.ukwhitegoods.co.uk/9957704-compatible-dishwasher-water-heating-element
    you would have to strip it and find it. Then disconnect the wires going to it and check the resistance with a multi meter. you looking for a low reading well under 100 ohms. if you get thousands its gone
    davepi18
    electrofix wrote:element should be this one
    Thanks for replying so promptly.
    Managed to strip it down today. The heater has 25 ohms across it, so that is fine. Tracing the wires back, the connectors all look good, the water pressure switch seems to be working as does the relay on the PCB in the control model (when I activate it with a 9V PP3 battery, the contacts move over and make the circuit). I conclude that it is therefore some other fault on the PCB meaning that the drive circuit to the relay has failed. Anything else it could be before I look to replace the PCB or debug it?
    Cheers
    just to check, when you tested the heater, did you test from the connector block or either end of the element ?
    davepi18
    Connector block. And the path between the connector to each end of the heater was showing 0 ohms
    #473059
    check temp sender
    its an ntc connected to teminals H1 and H3 on the board
    disconnect plug and measure resistance
