Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Ikea Valgjord not using salt
- This topic has 7 replies, 2 voices, and was last updated 3 years, 10 months ago by
Nicopod.
May 19, 2022 at 2:06 pm #100831
Nicopod
ParticipantHello
I own an IKEA dishwasher Valgjord
Model: 911434343/06The dishwasher is not using any salt at all. The level has not changed for months despite regular use of the machine.
As a result the glasses are coated with a white material (assumed limescale).Are you able to confirm the solenoid (attached picture 173131) is responsible for the dishwasher to direct the fresh water into the water softener unit?
How can I test it?
Is there another way to find what could cause the salt not to be taken?Let me know if you need anything else.
Thanks for your help.
Looking forward to hearing from you.Nicopod
May 19, 2022 at 7:02 pm #482346electrofix
Moderatorthat looks like the regen valve
have you checked it ?Dave
May 19, 2022 at 7:55 pm #482347Nicopod
ParticipantHi, I am not too sure how to test it?
I took it out.
It was moving freely.
I used the multimeter, checked for continuity. It was not working.
I checked the resistance it was indicating 3.7kOhms
Is there a way of testing it in place?May 19, 2022 at 10:44 pm #482348electrofix
Moderatorno you have done enough to prove its ok. at least the coil is
when you got the dishwasher did you test and set the hardness levels for your area ?
May 26, 2022 at 9:16 am #482349Nicopod
ParticipantHi Dave,
The dishwasher is 5.5years old.
It was taking the salt normally until recently.If it is not the regeneration valve what could it be?
May 26, 2022 at 9:35 am #482350electrofix
Moderatorwell thats a hard one
the regen valve and sofner umit is controlled by the timer.you would need to put it in service modes to see if all works
see if this helps
https://www.manualslib.com/manual/1419039/Electrolux-Edw-503.html
June 8, 2022 at 4:51 pm #482351Nicopod
ParticipantHi Dave,
I am not able to find the exact maintenance manual for our dishwasher.
I have the user guide but this is of no interest.
But having reviewed the document contained in your link (assummed similar system) I am not able to proceed further.
Are you able to assist me for next step?
Happy to discuss over the telephone (number to be issued by private message) if you have some time, as I am not very aware of repairing the dishwasher..
Thanks.N.
June 8, 2022 at 5:15 pm #482352electrofix
Moderatornot taking salt is not a fault I have seen, Yet, so dont know exactly what and when the regen cycle is run
Hopefully the manual might give you a few ideas
