Ikea Whirlpool 500 656 40 Oven
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Ikea Whirlpool 500 656 40 Oven
  • #43781
    This oven was not working and was displaying F03, which is listed as:
    F03 Oven power unit not configured Replace oven power unit
    The power board is part No. 4812 715 98024. I got a new board from Masterpart and was slightly dismayed to read in the instruction leaflet that it needs to be configured by cutting off certain resistors, determined by a service number on the serial number label. This meant that if it failed to cure the fault the board was no longer fit to use in another appliance 🙁 When I got back to the job I found that all 5 of the configuration resistors were still present on the original board whereas the instruction leaflet indicated that for this service code 9 oven, resistors 0 & 3 should be removed. I removed these resistors from the original board and it cured the fault 😯 I’m now hoping that Masterpart will accept the new, unused board back :rolls:
    #278567
    Re: Ikea Whirlpool 500 656 40 Oven
    thats mad how did it work in the first place long enough to get out of the guarentee and if whirlpool cant configure their own boards correctly how can we
    #278568
    johnmac11
    Look here at an old post I did and all will be explained.
    Factory fitted boards do not have the links cut and are pre programmed for each oven if the software goes haywire cutting the links can restore the board sometimes
    John
