Ikea/Whirlpool dishwasher 60cm wide and integrated
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Ikea/Whirlpool dishwasher 60cm wide and integrated
  • #16206
    winker
    cycle starts with water flowing into machine and drain pump running.Drain pump stops and continues filling,wash pump comes on and continues filling beyond normal fill level drain pump cuts in and start button flashes together with audible beeping.What controls fill level?
    I repaired machine with new infill hose assembly as solenoid valve was o/c,dont know whether over fill fault was there beforehand or has been caused by solenoid going. 🙁 🙁
    #168827
    Re: Ikea/Whirlpool dishwasher 60cm wide and integrated
    Water level is controlled either by air pressuer into a diaphragm switch or by a flow meter, depending on the model number……..
    winker
    saw a magnetic reed switch at bottom of infill manifold with what appeared to be a plastic impellor inside the manifold.found a microswitch fitted to water operated diaphram on the side of sump approx 2″ dia.are these the items you describe 😕
    #168829
    Please – tell us the numbers on the label on the edge of the door……. Also, the pattern of flashing lamps (1-2-3 pause repeat, for instance).
    winker
    service tag no. 8542 416 15710
    #168831
    winker
    have not noted light flash sequence as yet
    #168832
    winker
    when machine defaults because of overfill start flashes nine times
    #168833
    Dave_Conway
    It’s probably the flow meter in that case, if you have a read of this thread:
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=12186
    That’s basically the same dishwasher 🙂
    Power off please if continuing yourself :zap: or check the repairs@ link below if you need pro help.
    #168834
    winker
    have watched turbine wheel flying round in manifold,is that a magnet in the centre?also checked continuity through reed switch with magnet
    #168835
    winker
    refitted flow meter and metered reed switch whilst filling at slow water flow,switch is pulsing ok.started cycle again with water supply off and this time got six flashes which is probably time out?When your ready ,,thanks
    #168836
    Dave_Conway
    6 flashes refers to no fill which could be valve, flow meter, PCB etc….
    #168837
    winker
    flow meter and valves are ok.Is the fill level controlled purely by pulses from flow meter to control unit or does another device get used.the machine fills to an initial level when the wash pump comes on it continues to fill,doesn’t stop filling and then defaults with nine flashes.I should point out that at cycle start the drain pump comes on together with water.Its like the fill valve has a permanent live supply ❓
    #168838
    DentedPorsche
    The flowmeter works in conjuction with a pressure switch.
    If the flowmeter doesn’t send the correct number of pulses or the pressure switch doesn’t detect the correct amount of water in a given time the machine aborts the program.
    9 flashes indicates a faulty inlet valve or pcb. (Remember that the error codes are only a guide to the likely cause of the fault).
    Normally a flowmeter or pressure switch problem wouldn’t allow the machine to start washing before aborting.
    DP
    #168839
    winker
    Thankyou and all your team for your support on this one,at a time when a lot of manufacturers have abandoned Trade support its nice to know there is a lifeline when you need it.
