Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Ikea Whirlpool DWF B10 fault
- This topic has 21 replies, 4 voices, and was last updated 18 years, 4 months ago by
richard3009.
November 13, 2007 at 10:40 pm #32174
richard3009
ParticipantThe dishwasher fills with water but fails to start washing, if I open the door and hold down the start button for a few seconds the program can be cancelled, closing the door then results in the water being pumped out.
November 13, 2007 at 10:48 pm #233924gegsy
ParticipantRe: Ikea Whirlpool DWF B10 fault
This is a Whirlpool made unit for IKEA. Under normal fault conditions the start lamp should flash a certain number of times which denote a fault code.
Please count them and type back 😉Greg
November 13, 2007 at 11:17 pm #233925richard3009
Hmmm tough one when it is left for ages the water is heated and I assume after the normal running cycle time has elapsed, it bleeps intermittently instead of the solid long tone to indicate program finished, is the fault code only displayed if i let it run a so called full cycle.
At the moment the start lamp is constantly lit
November 13, 2007 at 11:31 pm #233926gegsy
When it bleeps quickly, open the door carefully and look at the start lamp flashes 😀 .
November 14, 2007 at 12:27 am #233927Penguin45
Sounds like no circulation……… And it will have one of these in it:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159Penguin45.
November 14, 2007 at 9:27 am #233928richard3009
Ouch if thats the case its looking like a £100 repair plus labour, time for a new machine maybe.
While Im on how do I remove the door facia front, that is fitted to this integral machine.
November 14, 2007 at 8:47 pm #233929Penguin45
Slacken the 2nd and 4th screws down on the inside of the door – the outer panel will drop away.
November 21, 2007 at 9:16 am #233930richard3009
The bloody thing ran ok for 3 cycles this weekend and last night circulation pump failed to fire up again, it tried to go for a split second then nothing, it just sits full of water, could it be a float not quite reaching a limit/micro switch?
November 24, 2007 at 8:10 pm #233931jonesy12
I have a 2 year old Ikea Whirlpool DWF A10 – it seems to be demonstrating the same fault as richard3009’s B10 and I’m keen to know what richard3009’s course of action was after his last posting.
My symptoms are:
Turn machine on and it makes a filling noise.
The water comes in and fills the bottom of the dishwasher – crockery is dry/damp – it doesn’t seem the water is coming from the rotating arms.
If left in the on position, it seems to be in a constant state of pause, heating the water at the bottom and not much else.
I can pump the water out, by cancelling the programme and pressing the start button for a few seconds.The A10 model that we’ve had never has had any bleeping noises – also the green on light is either on or off.
I don’t really have to dip into my back pocket to the sum of £200 which seems to be the going rate for the equivalent model at Ikea now. I’m lookinf forward to your replies and hope help is out there!
Many thanks – Jonesy12
November 24, 2007 at 8:18 pm #233932Penguin45
Penguin45 wrote:Sounds like no circulation……… And it will have one of these in it:
I think you’ll find the answer there.Penguin45.
November 24, 2007 at 8:22 pm #233933jonesy12
Rats; I was rather hoping you weren’t going to say that. Is it coincidence that an A10 and B10 give up the ghost after 2 years active service. Do I replace the dastardly device or do I go the whole hog and by a new one? Thanks, Jonesy12.
November 24, 2007 at 8:35 pm #233934Penguin45
That’s the replacement:
http://shop.ukwhitegoods.co.uk/product_ … cts_id=653Pretty straightforward to fit, though the locking clips can be rather awkward. Main thing to be aware of is the razor sharp edges everywhere.
If you replace with another Whirlpool, you’re buying the same dodgy pump – the replacements just don’t go wrong.
There is a slight possibility that the pump is blocked, BTW. Bits of chicken bone are quite capable of jamming the motor.
November 24, 2007 at 8:39 pm #233935jonesy12
Okay, that gives me a little hope! I will sign off for this evening and have a play around tomorrow. Have a good evening, Jonesy12.
November 24, 2007 at 10:36 pm #233936richard3009
Ended up buying another dishwasher for £200, just bought a bog standard Proline from comet, its washed the dishes tonight if it lasts 2 or 3 years years at £200 its a throw away item
November 24, 2007 at 10:40 pm #233937gegsy
For a bit more you could have bought a Bosch 😉
Why you no ask 😕Greg
