Ikea (Whirlpool) DWF417 slimline D/W
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Ikea (Whirlpool) DWF417 slimline D/W
  • #65443
    Johnnyboy
    Hi guys this little beaut will drain, recirc, heat, soap drawer open all ok but…. next time it drains and fills at the same time (pulsing) and you cant get it to do anything, I set off ther flood alarm, reset the programme and away it went untill the next time. Not able to try a test prog as it is a different set up from normal Whirlpools.
    Cheers Johnnyboy
    #360521
    Re: Ikea (Whirlpool) DWF417 slimline D/W
    could be either a Bosch or a smeg! need service number to id. Odds on its a Smeg given the symptoms. Start with the dispenser coil-end with the PCB or anything else in between.
