Re: ikea whirlpool dwh b10 4 flashes
Usually very simple…look in the sump at about the 3 o’clock position, you will see a grid which is probably clogged up. Clean it thoroughly with hot water and a toothbrush…don’t poke anything sharp through as there is a rubber diaphragm behind which you might puncture.
If it won’t clean up like that you will need to remove it completely (bayonets in from underneath) and carefully take it apart.
Power of at all times :zap:
