Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Ikea / Whirlpool FCSM6 oven stopped working
- This topic has 10 replies, 2 voices, and was last updated 5 years, 9 months ago by
Chrisandalex.
June 17, 2020 at 6:20 am #97839
Chrisandalex
ParticipantHi. I had the oven on yesterday. The power tripped. When I switched the power back on the oven powered up (timer and fan) but no heat. We use the oven two or three times a week for short periods (max 30 minutes). We’ve had it from new. Any advice would be great please.
June 17, 2020 at 8:16 am #469745electrofix
Moderatorprobably just an element failure. 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time if you fit a new element it will be fine
June 17, 2020 at 8:48 am #469746Chrisandalex
Participantthanks Dave. Could you recommend a supplier by any chance? thanks
June 17, 2020 at 10:12 am #469747electrofix
Moderatorlet me have the long service number off the unit 12Nc ????
June 17, 2020 at 12:26 pm #469748Chrisandalex
Participantthanks
reading the label from the left:
IKEA FCSM6 DV C10/S
Model 501 230 08 2.8kw
SERVICE
857921301510
390737017788
June 17, 2020 at 12:37 pm #469749electrofix
Moderatorlooks like it should be this one
https://shop.ukwhitegoods.co.uk/481225998405-whirlpool-other-fan-oven-cooker-elementthis is a genuine element. There are cheaper alternatives but in my experience they are worth the extra
June 27, 2020 at 10:12 am #469750Chrisandalex
Participantthanks. I have switched off power at the cooker plug. I have removed the cooker door. I have removed the two screws fixing the back cover plate.I can see the lugs that locate the bottom of the plate into the back. When I angle the cover plate forward (from top) it won’t go past the metal shelf supports on the sides. I’m assuming that I’ll need to remove one set of side shelf supports? They have metal bars that clip into the side of the oven (in fact the left rear one isn’t actually engaged). I assume that I pull the centre of the vertical bar on the front edge of the left unit to spring the top out and then remove the left side shelves to allow the back cover pate to drop down further to remove it? any advice would be great thanks
June 27, 2020 at 10:34 am #469751electrofix
Moderatorcant tell you how they remove. because its Ikea cant find an owners manual and that info may well be in there
but yes you have to remove them to allow the back cover to be removed
June 27, 2020 at 10:51 am #469752Chrisandalex
Participantthanks Dave – It’s basically a Whirlpool oven sold by Ikea.
June 27, 2020 at 11:24 am #469753electrofix
ModeratorChrisandalex wrote:thanks Dave – It’s basically a Whirlpool oven sold by Ikea.
yes i realise that but the owners manual wont come up on whirlpool site because its badged Ikea
June 28, 2020 at 5:49 pm #469754Chrisandalex
ParticipantJust to say a huge thanks for the help and advice on this excellent forum. The oven is now working again. Lovely stuff!
