Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Ikea/Whirlpool lower element change FCVM6
- This topic has 8 replies, 3 voices, and was last updated 12 years, 2 months ago by
TheMoog.
February 6, 2014 at 11:03 pm #79413
TheMoog
ParticipantHi,
I’ve bought a new lower element for this oven, but am struggling to find a means to remove the old failed one. I’ve taken the oven out of the cabinet, removed the rear panel and can see the wires and the nut holding it in place. From there I’m stuck. At the back is just the insulating material and foil surround, so it looks like the element has to be removed through the front once the nut at the rear is undone. I’ve disassembled as much as I dare, but can find no means of getting to the element without completely taking the oven to bits. I feel it shouldn’t be that hard so reassembled and tried from the bottom. Again no luck.
Can anyone help, this is really frustrating!
February 6, 2014 at 11:18 pm #409104RickT
ParticipantRe: Ikea/Whirlpool lower element change FCVM6
I,d re-check the model number, or better still the barcode number beginning with 8
February 7, 2014 at 8:42 pm #409105TheMoog
The 12 digit whirlpool ref is 857915415531
February 7, 2014 at 9:43 pm #409106kwatt
KeymasterRe: Ikea/Whirlpool lower element change FCVM6
I suspect that if you move the insulation out the way all will become clear.
February 7, 2014 at 10:00 pm #409107TheMoog
Tried that to some extent, but it appears to be behind the foil as well, which looks sealed. I’m assuming this foil layer shouldn’t be broken at all?
February 7, 2014 at 10:12 pm #409108RickT
Have you the part number of the element?
February 7, 2014 at 10:19 pm #409109TheMoog
Yes, 481925928847. I have it, just struggling to get the old one out!
February 7, 2014 at 10:22 pm #409110RickT
Remove screws on far left and right.Wires off. Pull out. Element may be distorted causing snagging, but it will come out 😉
February 8, 2014 at 9:59 pm #409111TheMoog
Ah, got it! Took the bottom panel off, moved the insulation and found the screws holding another tray which the element sits in. Easy(ish) after that. The old element had blown apart.
Thanks for the tips
