Hi All,
My own Ikea oven Mod:50065640 Serial No: 8541856115010 140319038412
has suddenly stopped heating on oven function.
Having checked the forums for previous posts/advice before buying an element I thought i’d check it first.
It’s sound with no distortion, and has 28.5 ohms resistance, so have re-fitted.
Upon re-starting the oven, the element heats up, although the main fan (middle back) doesn’t seem to be coming on, (but top fan does) and after a short while the element ‘switches off’ leaving top fan to run.
The main fan coil has 148ohms resistance and is getting 240v.
I think it has a thermister (or overheat stat?) which has 0.45ohms resistance.
Worth mentioning, is that the control has occasionally has started a program when in a different (off) position. It’s not doing it now, and only did it say couple times a year – Just needed the control positively put back to off position.
It’s 10 years old, but am looking to keep it going for a while more if possible.. any help appreciated.
Cheers
R
