Went out to this machine this morning, customer reported 11 flashes.
I did a trawl of the forums the day before and found several references to this fault coming up on machines that don’t actually have an OWI sensor.
This one, I think the model number was DWB10W or something, also has the normal diaphragm sensor.
The base was flooded. After draining the base the machine then worked perfectly, no sign of a leak anywhere.
Does this model suffer from over soaping like the Indesit dishwashers if the customer uses 3 in 1 or 5 in 1 tablets?
