In-de S**t Washer/ Dryer
  • #27540
    cornflakes
    model WD 10
    reported fault water taking in..short period 30- 45 secs rotation, then water drain.. Control knob starts rotating
    visted site found 2 quid in drain pump..cleared
    re-tested..same symptoms on any wash selection
    dryer working ok
    spin cycles working ok
    drain pump running ok
    only 2 lights on machine..door locked light flashing only
    any ideas
    Graham
    #214539
    macmini
    Re: In-de S**t Washer/ Dryer
    Is the light flashing in a pattern when the knob rotates?
    It should be flash flash flash pause flash flash flash.
    Count the flashes between the pauses.
    #214540
    The error codes are given out by the Mains neon, not the door lock neon, 😉
    Worth checking/changing the brushes, can cause this fault even though it will spin.
    helo_75
    its a washer dryer remember
    my moneys on the dreaded 8 flashes
    heater relay stuck!!!
    #214542
    suedehead1
    These machines are bad for water dripping onto the circuit board from the dryer as you probably know.
    you could always try changing the presure switch it can also cause that type of problem.
    on the bright side you are still £2 up on the day.
