Would someone with the Whirlpool fault codes for dishwashers have a look at the “known error code” thread in this forum and let me have the one’s that are missing.
It appears from the post in the public forums today that F6 does actaully exist but is missing from the list here.
OK Dave I’ve updated the fault codes for Whirlpool dishwashers, I’ve only recently come into possession of the full list of codes for Whirlpool appliances (previously only had the codes from the SAM module).
I’ll post more as soon as I get time to type them up along with the test programme instructions (if I can find them). May be some time before I can do this as my wife is out of hospital today and coming home for me to look after her.
water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
water tap closed
water inlet hose blocked
water inlet valve (WV1) defective
flow meter (FM) defective (leads to FM failure)
