Incontinent Ariston Margherita 2000
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Incontinent Ariston Margherita 2000
  • #5917
    Hello!
    My washing machine is incontinent. It’s an AB54 (Italian model)
    The program seems to run just fine, but the drain valve is always a little bit open. No error codes, no leaks outside the drain, but a constant flow through the machine.
    Suggestions?
    /Swede
    #114600
    Re: Incontinent Ariston Margherita 2000
    Swede,
    Drain Valve???? Do you mean that the water is constantly flowing out as soon as it comes in I wonder?
    I suggest if that is the case to make sure the outlet for the machine is above the water level. To prevent syphoning as it were. Usual rule is at least 50cms above floor level 😉
    If by Drain Valve you mean Water Inlet Valve keeps filling, then you need a new inlet valve 😉
    Hope that helps?
