ind d/washer
  • #36618
    dopper
    got a ind dv620kixuk dishwasher
    it was leaking
    the leak was coming from the sump where a switch had come out
    what i need is a clip that keeps this switch in place, its to small for a jub clip
    anyone help
    paul
    #251703
    bzz67
    Re: ind d/washer
    not sure which switch your refering to, but a zip tie can sometimes replace a hose clip with good results.
    #251704
    Re: ind d/washer
    Not if you use a very small jubilee clip, they do make them small enough, have refitted two or three of these doofers.
    I’m assuming its the little switch that fits into the side of the hose that goes to the bottom spray arm.
    Plastic cable ties are OK if you want to run the risk of it blowing off and flooding again. 😉
    dopper
    Re: ind d/washer
    tried the ties kept dripping
    #251706
    Re: ind d/washer
    They do make jubilee clips small enough for this job, honest. 😉
    jim.
