ind idl40
  • #69606
    dopper
    code is 1 and 3
    seen 2 dif codes in book one says blocked filter other say wash motor it fills then pumps out and code comes up filters looked ok?
    dop
    #375360
    johnnyj
    Re: ind idl40
    Check spray arms, and also for an air lock in pressure hose which can cause this fault also.
    #375361
    dopper
    Re: ind idl40
    cheers i remember now i had one where it was the arms
    #375362
    mike1
    Re: ind idl40
    just fixed one myself,air lock in pressure hose,good advise.
    thanks
    mike
