ind w113
  • #16910
    dopper
    ind w113uk timer clicking round flashing 10 times, pressure switch needs to be changed?
    ive checked the p/s hose the machine fill once then pumps out,if i take the hose fron p/switch let it fill past fill level then blow into switch it works ok so i think its a new p/switch
    is that right
    cheers paul
    #172112
    aqualectric
    Re: ind w113
    Have you checked the carbons? Just uneven wear on them can cause fill faults. If the pressure bottle is clear and the rubber hose is clear and not holed, could be pressure switch; but they don’t fail often.
    Hope this helps,
    Steve.
    #172113
    dopper
    Re: ind w113
    went back to job checked carbons ,took all hoses from pump to see if blocked, cleared the side hose that goes to side of drum and its working ok now
    cheers
