Hi all
Any ideas on this one,
Customer rang and said the knob was continually turning,Iasked him to check how many times the lamp was flashing, he said twice.
He rang back later said the machine was working OK.
Seems it only worked once,as he rang again to say he was still having a problem.
Called to fault ,set up machine on wash prog door switch opperated light stayed on , nothing else happened.
Reset program tried it on empty prog same thing.
Checked live through door switch OK,Live and Neutral getting to Module OK.
I suspect a problem with the module, any suggestions 🙁 ❓
