Hi Bernie
Went to this call to day it comes up test end f03 When you switch the machine on it starts with out starting it all so will not stop if you press the off button. Is the thermistor located in the heater. Disconnected but still will not play ball. Can you help thanks Les
LittleMan wrote:will not stop if you press the off button
Sounds like dodgy pcb. Either fascia pcb with iffy tactile switch(es) or main board. If main board could well be a capacitor in power supply. This one might have the 680uf / 10v like HPT.?
Mike.
