indeit oldie, 1069w
  • #51237
    adv
    machine spins drains, but wont wash, can here heater comin on but, no control o thermistat. when turn down to cold wash no click, an if mind shud start to distrabute. any tips guys? 😆
    #307345
    Re: indeit oldie, 1069w
    Think those old ones don’t start to distribute till temperature is reached. Try bridging across the variable stat (think there’s only two terminals?) to make it think temp has been reached. Probably stat is obsolete by now though.
    Mike.
    #307346
    aqualectric
    Set it to the rinse cycle and the drum should turn if it is the thermostat at fault. Check brushes and tighten the connector strip on the PCB.
    Steve.
    #307347
    adv
    it rinses and spins fine
    #307348
    So, is the vari-stat actually making and breaking the circuit?
    adv
    havent got that far yet. no cilck when turn state down. was in rush didnt have time pull m:achine owt 😆
    #307350
    The vari-stat starts and stops the timer at the heat position – it does not turn the heater on and off.
    adv
    i remember if u wanted to get the machine to advance an distribute on wash u turn to cold on state. do this an timer doesnt advance an no turn, as i say no click/. wat u wrekin mate state?
    #307352
    Yup.
    C.
    #307353
    adv
    have good new yearcheers 😆
