indersit di 61 won’t program
Home Forums Public Support Forums Help And Support Dishwasher Help Forum indersit di 61 won’t program
  • #74740
    mick a
    d/washer is several years old and has been faultless till the last time my wife used it,she went to switch it on sunday after lunch the normal way and no program lights displaying? red standby lights up, program button ‘clicks’ but d/washer dead, nothing, any clues?, i am a registered gas boiler servis an maint/eng and i’ve looked behind the ‘dashboard'(with the power off of coarse)and noticed a pcb behind,would it be that??? can you buy them separately?
    #392720
    Re: indersit di 61 won’t program
    Using a circuit tester you should be able to check if there is a circuit from the mains up to the pcb via the on/off switch and the door latch switch with the machine unplugged.
    Pcb is available, part number C00060086 it is over £90.00 though. 😥
    #392721
    mick a
    cheers,i’ll check that out,price is about right, i looked on espares, comes up as dash board or panel? does that mean pcb and prog/select display comes in the panel with main switch,etc?, thanks for answering so quick, much appreciated.
    #392722
    They give them several different names, Indesit even call one pcb a 100bit timer. :rolls:
    That is the correct part, but I have never fitted one to such an old machine so I don’t know exactly what is in the box.
    #392723
    mick a
    i’ve just read your reply, i’ve just been on to espares site and i can’t find it? i’m not sure now where i saw it, i’ll have to do some more looking? thanks very much for your time, i’ll phraps let you know the out come, much appreciated, cheers.
    #392724
    mick a wrote:i’ll have to do some more looking?
    Try looking on Indesit’s own spares web site and not those con merchants eSpares. 😉
