Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › indeset we16 fault code F05
- This topic has 11 replies, 4 voices, and was last updated 21 years, 5 months ago by
admin.
October 23, 2004 at 9:00 pm #6606
KeymasterNow then I have had the pump out stripped and cleaned it nothing found blocking the impeller or any of the pipes , what else could it be and can I repair or replace the faulty part or parts , by the way is that an air pressure switch that as the small bore pipe attached to it, sits clipped to the top side panel ? could this be faulty ? thanks Gaz
October 23, 2004 at 9:56 pm #118630Dave_Conway
ParticipantRe: indeset we16 fault code F05
F05 certainly refers to a pressure switch related problem, which is the part you have mentioned gaz.
I don’t have the tech info here at home to help you with the part information unfortunately, someone else may, if not I’ll get back to you on Monday. 😀
October 23, 2004 at 10:43 pm #118631admin
KeymasterRe: indeset we16 fault code F05
Thanks for that Dave ,I ran the machine tonight on program 4 and it ran ok right up untill near the end and the F05 came up! thought I had it sorted ! it all so dumped all the water and started to spin . so I think theres more to this than a blocked pump . any way its late and the Newcastle brown needed some help ! I shall be chuffed if you can help Monday thanks Dave ……………….. Gaz
October 24, 2004 at 10:31 am #118632Martin
Gaz,
It’s not certain the fault is caused by the Pressure Switch or the connections from it to the Control Module. Also there are 3 different Pressure switches fitted to this model, so we would need the full model and the serial number first.
Do check that the drain pipe outlet is not restricted first 😉 On occasions getting an F05 error warning means the ‘drain out period has elapsed’ and therefore the machine goes into error. In fact the machine should drain from full to empty in less than 60 secs, if it takes longer it could be restricted 🙄
Pressure switches do indeed go faulty though, so it could be that?
October 24, 2004 at 11:09 am #118633admin
Thank you Martin, I shall go and have another play with the machine and check the drain opperation . I will all so get the serial number which should help Dave your self and any one else that cares to help me Thanks lads Gaz
October 24, 2004 at 12:14 pm #118634admin
Ok there are a few numbers I can find
Type number A13 LB 2000c
WE16 uk 080251620130 31040 305283774
on the drum there is 7400149301G 1600 C5 EVO 2
Are these numbers of any help ?
GazOctober 24, 2004 at 4:54 pm #118635Martin
Well if you do want a replacement Pressure Switch for that machine of yours it’s Part No: C00075337 (Cost around £15 ‘ish)
Just let us know 😉
October 24, 2004 at 5:29 pm #118636admin
Thanks Martin,
but how do I check that the one I have is inop ?
Also would it make any difference if the pump filter is missing ,it is part of the bung with two legs and a donut type ring fitted to it ,this part or bits where gave to me today by my darling 🙁 ???????October 24, 2004 at 5:38 pm #118637Penguin45
ParticipantThe ring on the end of the two legs acts as the inlet orifice for the drain pump. The machine will NOT pump without it being fitted as the pump is effectively open sided, so no pressure will be generated.
If the filter is actually broken it can be replaced as a spare part (IIRC) rather than the entire pump assembly. DC should be able to advise on Monday.
Penguin45.October 24, 2004 at 6:06 pm #118638admin
Penguin45,
I am not being funny but yer know thats just what I thought !
I was not aware that it was missing as I had no reason ever to look inside the filter housing before and did not no that it should be there as it had snapped clean from the bung ,But looking at the pump impeller it did not seem to be at all high tech! I shall replace the filter bung and see what happerns .place yer bets lads !!!!!! cheers GazOctober 26, 2004 at 8:58 pm #118639admin
Sorted its fine now thanks all for helping me ,it was a silly fault in the end ……. Gaz
October 26, 2004 at 11:17 pm #118640Penguin45
ParticipantWe aim to please…….
P45. -
